52 TO30 Exhaust Manifold Gasket Replacement
   / 52 TO30 Exhaust Manifold Gasket Replacement #1
VA TO30
Winchester, VA
52' Massey Ferguson TO-30
All,
I found out that I need a new exhaust manifold gasket on my TO30. Looking at the 8 or so bolts that hold the manifold on it doesn't seem that I can get access to atleast 50% of the bolts due to clearance issues between the bolts and the manifold. Can anyone provide any further insight on how I can go about removing all of the bolts so I can replace the gasket??
Thanks!
   / 52 TO30 Exhaust Manifold Gasket Replacement #2
The last time I had mine off (about 15 years ago) I had some difficulty get onto some of the bolts especially the middle ones. I used an open end wrench,a lot of pentrating oil and patience and got them off.
   / 52 TO30 Exhaust Manifold Gasket Replacement #3
All,
Thanks!
I plan on replacing all of my exhaust from the manifold back. Here's what I have planned. First you need to remove the gas tank. Why? You can't clearly put a socket on it from the front but you can access it from above as already mentioned. Use a line wrench if you can't get full clearance with a boxed end. An open end as last resort. It's pretty easy to remove the tank. If you need to use heat to free up the bolt, then no gas danger.
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2025 AGT 750 (A50123)
