zacsmith99
Evening All,
I have a 1952 Ford 8n. The lift will not work at all, even with the arms disconnected. I had a neighbor replace his recommended parts after inspection and they include, Lift piston, rubber and leather gasket, lift piston cylinder, and the pressure relief valve. With PTO engaged and the lift lever in the up position, the fluid on the inside moves very little, only enough to be from the PTO and the square pistons moving. I ensured the control arm was connected to the pump. I removed the bolt on the side of the bottom cover and drained what I assumed was a lower cylinder port. maybe half a quart came out. I cranked the tractor with this bolt out, pto and lift engaged and maybe got .5 gpm, not the rush I would expect. I replaced the bolt, topped off the fluid and cracked the top cover 1/8 of an inch and then cranked and lifted, roughly the same result, mild flow running out the high pressure line/top cover junction. with everything sealed back I grabbed the lift arms and moved them up and down fairly easily. I couldn't tell if the lift arm piston was supposed to be connected or if it just floated in the tube. I feel my next step is to rebuild the pump, Does anyone have any other suggestions or troubleshooting steps that may help pinpoint the issue?
Also worth noting the issue started in the winter. The scraper blade I was using at about 300lbs. I noticed the blade was dragging way low and couldnt lift it back up. I turned the tractor off, checked fluid, removed blade, and it started working again. Re-Attached blade, scraped and lifted as normal for another 30 minutes and then realized that the blade was low again. It hasn't lifted since.
