5105 Starting Problem
/ 5105 Starting Problem #1
texstrk426
Tioga, TX
John Deere 5105
A few months ago I posted a thread about starting problems with my John Deere 5105 all-wheel drive tractor. We mistakenly had put some gasoline in the fuel tank. I finally determined what the problem was after repeated difficulty getting it to start and then drained the fuel tank and put new fuel in. The injector pump had to be primed several times before it would start. It has been stubborn to start ever since and lately with the cold weather it simply will not start. It cranks fine at normal cranking speed. I have not primed the injector pump lately to see if that would cure the issue. I have a suspicion that the injector pump is the issue because once the engine started in warmer weather it ran OK.
Is it more likely that the injector pump will get damaged by having gasoline mixed into the diesel fuel or is it more likely the engine has been damaged to the point it is going to have to have the engine rebuilt? I tend to think it is the injector pump, but what about the injectors themselves?
Joe
/ 5105 Starting Problem #2
Did you use ether as as a starting aid when diesel was diluted with gasoline? Only way to know if injectors are faulty is remove them & have them pressure tested. I doubt diesel diluted with gasoline ruined injection pump but stranger things have happened.
The tractor was operated for probably 30 minutes to an hour with the presence of gasoline in the fuel before it bogged down and stopped. There was toward the end of that time some clattering or pinging going on. At the time I did not know what was wrong. The problem of hard starting became worse as colder weather came about. The last time I tried to start it (last week) it cranked and cranked and no amount of throttle movement or pumping of throttle would get it to fire.
Back when the contaminated fuel had been removed from the tank and new diesel fuel added, I had to prime the injector pump the several times before enough of the gasoline was cleared from the lines as well as the injectors before the engine would start. I used the procedure in the owner's manual. My suspicion is that the cold weather has caused some parts in the injector pump to shrink just enough that there is poor or low pressure going to the injectors. I may be wrong. I have no gauge to measure the injector pump pressure and perhaps I need to have my dealer send a man out to test the unit and make a diagnosis.
Is there also a test for engine compression by removing injectors and testing each cylinder? I would think so. That would be another means of evaluating the situation.
Joe
/ 5105 Starting Problem #4
You can check compression by removing injectors and using a proper adapter in injector bore. Before you get that involved, you should check to be sure you have 12 volts being supplied to the injection pump wire on top when key is on. If you do, definitely go through the procedure of bleeding out the fuel. Loosen the 17mm line in the center of the rear of the pump and then pump the primer button on top of the filter until you get good fuel flow at that fitting. Then tighten that fitting and loosen the other lines on rear of pump going to injectors. Crank the engine until you see good flow of fuel spurting out of each line. Tighten the fittings and then crank for another 15 or 20 seconds and engine should start. If you have fuel supplied to pump and voltage supplied to pump, you should get fuel to pump out when cranking. If not, then injection pump may be damaged. Since you have had engine running since the gasoline was in it, I doubt the pump is damaged now, but it is possible.
/ 5105 Starting Problem #5
If the engine is running, chances are the inj. pump didn't get harmed..
IF you had enough gas in the system to dilute the diesel fuel to harm anything.. it would have seized the pump & or injectors..
Both rely on the fuel for lubrication..
MY thought is the "lift pump".. it has a rubber diaphragm in it.. you know what gasoline does to rubber..
They're only $40.00 & well worth the swap.. rather than the $1000.00 inj. pump.
Good luck & keep us posted.. TPG
/ 5105 Starting Problem #6
How long was engine run since gasoline diluted diesel was exchanged for good diesel? Before I spent the money to check injectors or compression I'd try to get engine started then run it for an hr or more. Once it had been established that IP has a good fuel supply if it was my tractor I'd attempt to "tow start "it because I think 5105 has no hyd drive function .
The tractor was used to mow some property for more than an hour after the events that led to it having the gasoline in the fuel. Therefore the injector pump may be OK. However, I need to do as was suggested; check for the 12 volts at the injector pump, then go through the bleeding procedure for the injector pump input and then for the injector pump output lines too. As to pull starting the tractor, I do have a Dodge pickup with the Cummins diesel and a heavy duty chain with hooks that I could use to do that if it becomes necessary. I don't think this tractor has an extra fuel pump in it. The line comes from the tank directly to the fuel filter where the manual bleed pump resides in the line going to the injector pump. I will double check to make sure though.
Thanks to all of you for your help! It will be a while before I get around to further tests. It is very cold this week with temperatures going down into the teens overnight and staying below freezing all day. Brrrrrrrrrrrr!
Joe
/ 5105 Starting Problem #10
texstrk426
The reason I suggested "tow starting" is that I once owned a tractor that when it was accidentally run out of fuel due to none operating fuel gauge was very difficult to get started even after intensive bleeding BUT I would tow it not over 5-10 ft and it would start right up. If you decide to attempt to tow start it utilize a higher speed gear.
Jim;
OK thanks for that input. One of my problems is that the tractor is currently inside our barn with a group of huge heavy 6V batteries on a pallet in front of the front-end loader of the tractor. If I decide to tow the tractor it will have to be first pulled out of the barn backwards. It can be done but will have to be done in dry weather so my pickup won't bog down in wet soil. My pickup is a Dodge with Cummins diesel and the front end is very heavy tending to sink down in wet soil and does not have 4-wheel drive. However it remains as an option.
My thanks to everyone who has offered suggestions!
Joe
Update on the starting issue with the 5105 all-wheel-drive: I have had to frequently prime the injector pump in order to get it to start. It appears that once the fuel level in the tank drops to some level less than 3/4 tank on the fuel gauge that the injector pump loses its prime. The condition is worse in cool temperatures. When temperatures are low, even bleeding the injector pump will not get it started. I found that if I heat the injector pump with a heat gun for a few minutes that it will start OK after bleeding.
Some months ago I did find that connections from the ignition switch to the relay that sends voltage to the injector pump wire were corroded. I took time to clean the connections of the relay and the wire lugs that connect to the relay. I used some fresh chassis grease to keep oxygen and moisture away from the connections after the cleaning procedure. The starting issue did not change however, so although it was good to clean the connections, that was not the problem. There is one other relay just like the one for the ignition and you can swap them for a test, but that makes no difference in starting either. I consistently see 12VDC to the connection on the injector pump with ignition turned on.
There are two fuel lines that connect to the injector pump other than the ones from the pump to the injectors. One line connects to the top of the pump and the other connects to the center of the back side of the pump near the injector lines. I think the line connecting at the rear of the pump is the one from the fuel tank. What is the other line? Is it a return line to the fuel tank to bleed off fuel that is not being injected to the cylinders?
The tractor was at my dealer recently to repair the rockshaft assembly (spool valve was replaced to correct arms stuck in up position). While the dealer had the tractor they said they never had trouble starting the tractor. I made sure it had a full tank of fuel before it was picked up.
One tech at my dealer said that he thinks the injector pump either needs to be rebuilt or replaced based on my description of the starting issues the tractor exhibits. I have a diesel pickup too and a number of experts on the pickup say that rebuilt injector pumps do not last long and that a new pump is the best and longest lasting cure if an injector pump goes bad.
If the injector pump is replaced, are there any special precautions about how the new pump goes on the engine? Is there a keyed shaft that only mates one way or can it be reinstalled with shaft 180 degrees off and mess up timing?
Joe
/ 5105 Starting Problem #13
We have the same engine. I have attached a page from the engine manual ctm125 that should answer your question on lines connected to the injection pump and how to remove the pump. I do suggest you purchase ctm125.
Here is a post you may find informative. Must admit I am not a fan of using either.
https://www.tractorbynet.com/forums...hn-deere-5103-starting-issues.html?highlight=
Before removing the injection pump here is a couple things I would try; 1) Make sure the water separator on the fuel filter is closed; 2) Make sure the fuel filter is on tight; 3) Close the fuel shut-off, then disconnect the fuel line from the tank at the fuel filter and make sure you have a good flow of fuel from the tank. You should NOT need to bleed the tractor after doing this; 4) Remove the fuel tank cap, then using compress air from the engine side blow out the fuel return line. I have attached a picture that shows where this is, taken from TM1792. I read post that a person said this was their problem; 5) If you can get it started. After turning off close the shut-off at the fuel filter. Let the tractor sit for hour or 2. Then see, if it starts. It will only run for a few seconds, because the fuel shut off is closed and you will need to bleed it, but if does start the problem is between the tank and the fuel line.
  • 5105 fuel system.pdf
  • 5105 injection pump.pdf
JD5210
Thanks for the *.pdf files! I will study the information and familiarize myself with all the parts of the system shown therein. After that I will be much better prepared to diagnose the real cause of the trouble.
We just had a cool front blow through this morning and from past experience with the issue, it will become more difficult to start when it is 48 degrees F in the morning.
Joe
/ 5105 Starting Problem #15
I had a 5310 for 18 years and worked on many issues over the years. It sounds like you do have some sort of fuel flow issue but I was thinking there could be some problem with the fuel shutoff solenoid. It maybe failing closed when it gets cold. I agree with 5210 that you should go through the steps to make sure you don't have restricted fuel flow first. If that is your issue it won't break the bank to repair it. If you find the fuel delivery system is good then the last option I see is removing the IP and taking it to someone to have it repaired.
As a follow-up I found that the 12VDC at the injector pump fuel solenoid is present during key moved to the run position but not to the crank position. Then if the key is moved to the crank position, there is still 12VDC on the injector pump fuel solenoid. However as soon as the key is released to go back to the run position the voltage goes away from the injector pump fuel solenoid and the engine dies.
I discovered that if I unplug the lower left relay from the bank of 6 relays at the lower left side underneath the instrument panel I can start the engine and when the key is released back to the run position the tractor remains running as normal.
Could the cold start engine block sensor cause this? I need to check all the fuses tomorrow and see if any are blown. Is there a picture that shows the function of each relay in the relay bank?
I stopped after the sun went down. Tomorrow I plan to check each fuse in the fuse panel. The 20A going to the injector pump fuel solenoid was good.
/ 5105 Starting Problem #17
Is there an electric cord coming from the bottom of the injection pump.?? It’s a CSD, cold start device.
It should run up to a connection at the thermostat neck.. UNPLUG IT & try it out for normal operation..
CATERPILLAR 314EL CR EXCAVATOR (A64277)
CATERPILLAR 314EL...
3148 (A63117)
3148 (A63117)
2022 EZ-GO ELITE...
2000 Hino (A64194)
2000 Hino (A64194)
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
