Oil & Fuel 5103 oil change
/ 5103 oil change #1
John D
Johnson co. TX.
JD 5103
OK give me the tricks you guys use for makeing the oil change alittle faster. draining and changeing the filter. no prob. refilling with 9 qts. a pain in the butt. I had to use a msr cup and pour real slow or it would overflow back through the filler hole. not like the Ol truck were you can just open the bottle turn it over upside down in the filler and leter glug till it was empty and ready for the next qt. jb
/ 5103 oil change #2
Its too bad the mouths of oil containers are bigger now. They won't even fit into the fill holes anymore. Greg.
/ 5103 oil change #3
Does it have another filler cap? My 955, which admittedly resembles your 5103 about as much as a rhinocerous does a crocodile, has two fill caps. One is on top of the valve cover, the other one's down along the side of the engine. When I pour it in the one on top of the valve cover, I have to be careful how fast I pour, but, when I use my longer necked funnel and pour it in down at the side filler cap, it must have a straighter shot to the crankcase or something, 'cause in it goes lickety split!! :)
