5065E seat bolts work loose
   / 5065E seat bolts work loose #1
crowbar032
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
I'm having trouble keeping the bolts that hold the seat on the tractor tight. There are only two bolts, I guess the movement side to side just wiggles them loose. The front one seems to come loose faster than the rear one. There isn't a lock washer on them, but I'm not sure it would to any good. I'm going to use a crapton of locktite and really torque them down if no one has any ideas or it's just my tractor with the issue. I guess another alternative would be replace with a stud and put a lock washer and nut on the top.
I've re-tightened them a dozen times. Anyone else have this issue? Correction or fix for it?
   / 5065E seat bolts work loose #2
My suggestion is to put some Loctite on them and see how that works.
   / 5065E seat bolts work loose #3
Ditto on the Loctite
   / 5065E seat bolts work loose #4
crowbar,
I would suggest using lock washers AND some type of thread lock on them. ( Such as locktite ) Let the thread lock set up for at least a couple hours, then ROCK AND ROLL. :2cents:
Dave
Well it appears that the threads have stripped. I'm going to try one of those coil inserts.
200722 (A51247)
200722 (A51247)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
