5065e PTO clutch cable adjustment
   / 5065e PTO clutch cable adjustment #1
Rmiked
Fort Mill, SC
John Deere 5065e, 2013
Getting ready to do the first PTO clutch cable adjustment. My tractor is the 9x3 transmission with PTO lever on left side of seat. Is the adjustment Yoke easy to access? Do you need to remove any cover or disassemble anything? I am going to do the foot clutch adjustment as well and I see that is very easy to access. Just wondering if PTO cable similarly easy. Have not examined that area in detail. Both the foot clutch and PTO clutch are engaging and dis-engaging normally; no slippage. I only have 270 hours on tractor.
I successfully adjusted my clutch pedal free-play adjustment to 20mm . It was easy. I also successfully adjusted the PTO clutch cable. I learned the location of the PTO cable adjustment Yoke is under the foot platform beneath the clutch pedal. I initially thought the PTO cable adjustment Yoke was near the engagement handle which on a 2013 vintage 5065e, is to the left of the seat. Both of these were adjustments that don’t require a trained mechanic. Thanks
Guard Rail Pieces (A51692)
Guard Rail Pieces...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
