country101
So, I was bushhogging and the "Engine Air Cleaner Restriction Indicator" and "Service Alert Indication" started flashing. Based on this, I tapped off the filter that had a lot of dirt in it. Put it back in and went another couple hundred yards and they started flashing again, but went off before too long by themselves. I went further and then the "Engine Information Indicator" and "Engine Stop Indicator" started flashing. I shut the tractor down quickly once I saw the stop. I have replaced the air filter now and tried to start the tractor. It turns over, but does not start easily. I have gotten it to crank several times and it runs for about 15 seconds before it shuts off like you turned the key. The last few times the "Service Alert" and "Engine Information" lights come on. When it starts, it runs like there is no problems and sounds good. Anyone know what this might be or how to fix it?
I have disconnected the battery and am leaving it off until tomorrow and I am wondering what the sensor is just past the air filter box. Mass airflow or the air restriction indicator? The only other thing that I have seen looking at the one thread I could find is that someone had an issue with the cold start temp sensor.
