5065 E safety switch
/ 5065 E safety switch #1
Brad Erwin
Greeleyville, SC
JD 5065E
while bush hogging, the tractor equipped with auto reverser quit rolling and the PTO shaft stopped turning. Upon inspection, I found a small white and red wire both pulled loose under the floorboard(left side of transmission) My assumption is thowe wires send power to a safety switch that is no longer working due to lack of power. I cannot determine where those two wires are suppose to connect. CAn you point me in the right direction? Thanks
PS: the tractor will crank, it just will not go forward or backward, nor will the PTO engage
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
3147 (A63117)
3147 (A63117)
John Deere 995 (A64126)
John Deere 995...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
