5055e flashing N
   / 5055e flashing N #1
Needville
Needville
John Deere 5055e
I didn't want to disrupt the other thread, but I have a new to me 5055e with the power reverser 12/12 that gets stuck in neutral and flashes N on the dash. If I move the power reverser lever back and forth 15-25 times it will usually come into gear until the next time I have to use the lever, and then it is stuck again.
It throws codes of 524020.31 and 524021.31 which are both related to the power reverser. I am pretty convinced it is the power reverser switch that is bad. I can't figure out what the correct part number is for this switch. (it is located on the column).
Does anyone know the correct part number? Is there something else I should be checking before I buy the part?
Thanks in advance for your help.
   / 5055e flashing N #2
Transmission stuck in neutral or it is hard to shift any gear
Problem...Speed shift linkage stuck or rusty.
Solution...Clean or lubricate the speed shift lever linkages
Problem...Interlock cable misadjusted
Solution...Adjust interlock cable per technical repair manual
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
