5000E cab radio
   / 5000E cab radio #1
franco pags
New Hampshire
John Deere / Kubota
Has any one put a radio in one of the 5000E cab tractors
   / 5000E cab radio #2
We have installed several. Pretty easy plug and play. You just need to install a ground wire which isn't furnished. Assuming that you install the factory radio. Aftermarket radio probably will need an adapter .
   / 5000E cab radio #3
I think the VW adapater works? Do a search on here, I believe another memeber has done this successfully.
   / 5000E cab radio
Great thanks can you tell me what is the make and model of the factory radio.
   / 5000E cab radio #6
Mine is a Jensen JHD1130
How do you like that radio? I'm replacing my factory radio and called the guys at Crutchfields trying to find one with the Weather band and that's the series they recommended. They have three different versions with different options.
jensen heavy duty at Crutchfield.com
Thanks!
   / 5000E cab radio #7
I don't know yet. I have only had the tractor a few days. The radio is a basic am/fm with weather band and input jack. No satellite radio or anything like that. Seems fine to me.
UNUSED Galvanized Steel Diamond Plate Sheet Metal (A53117)
UNUSED Galvanized...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Aluminum Boat Top (A53117)
Aluminum Boat Top...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
Light Tower (A52377)
