Comparison 50" used Zero Turn vs Tractor with 60" finish observations
   / 50" used Zero Turn vs Tractor with 60" finish observations #1
Tifford
Bronze Member
Jordan
Mahindra 25 hst
My lawn is moderately hilly, about 5 acres, trees here and there.
Tractor is a Mahindra 25horse diesel new with a very used Italian 60" side discharge finish mower.
Zero Turn is a Toro 725 cc Zero Turn that is very used.
Advantages of Tractor.
Nice seat, hydrostatic foot control, straight line speed, 4 wheel drive option, quieter than the zt, less bumpy ride, diesel doesn't go bad like ethanol does, tractors are very handy for a lot of jobs, the tractor feels less stressed than the zt while mowing, In a straight line in 2wd the tractor feels like it would win a race. I have not verified speed though, you're further away from the grass clippings, seems to use less diesel than the zt does gas.
Disadvantages of Tractor
Tree limbs that you can run into because you're up high, not as tight of a turn, you sometimes twist your head to see where the mower is, a new tractor does cost more $.
My Toro ZT is used and I just got it. The maintenance was not kept up on it. It struggles to go up hill and it has difficulty turning right. I'll take it to a dealer and have a tune up done on it when time allows. It beats on you when the ground turns rough. It feels like only the right tire pulls hard while the left tire doesn't pull very hard.
I can see that if you have a properly running zt that it would be great on a lawn that has obstacles.
I would take a tractor with a finish mower in a second if there's not many obstacles.
   / 50" used Zero Turn vs Tractor with 60" finish observations #2
I have similar setup and my thoughts are the ZTR is better except when the terrain becomes un passable with the ZTR. Using machine specific specs like power output and seat isn’t exactly fair for a ZTR VS tractor comparison. The top speed of the tractor is better than my ZTR, but my L3800 with my 72” finish mower stands no chance of laying down more grass than my 428D Grasshopper 72” deck. My B7200 with my 60” finish mower stands a better chance against my 50” Dixie chopper but in good mowing conditions it’s still going to loose. The b7200 is by far the closest thing to indestructible and un stuck able mower that I own. I don’t think I’ve ever had that tractor stuck and it’s not because of lack of trying.
4570Man,
I agree. I had a bad 1st experience with this ZT due to poor upkeep from the previous owner. It came with the house. I can see a ZT saving time. The next time I mow with it I'll wear hearing protection that I use on the range. Once the lack of power on the left wheel is figured out I'm sure it will be better. Til then I'll use the tractor on the wide open spaces and the zt will make left turns around the trees.
   / 50" used Zero Turn vs Tractor with 60" finish observations #4
Is this an ether or? One or the other? A zero turn is pretty much one dimensional. Cutting grass is only a small part of what I do. There are endless possibilities with a tractor. Hauling wood, grading a driveway, plowing snow, moving dirt. See where I'm going with this. Having a front bucket beats a wheel barrel hands down. If you live in a neighborhood and all you plain on doing is cutting grass than a zero turn will probably work. But, if there is any chance of doing any of the above? I would get a tractor. Unless you have a ****-ton of money then buy both.
   / 50" used Zero Turn vs Tractor with 60" finish observations #5
My neighbor wanted a small tractor and his wife talked him into a zero turn because she likes running around on them, now he's always belly aching that he should have gotten a tractor every time he has to do something that he can't with that new fancy mower. And I would be real careful about buying a used zero turn, sellers like to paint them up real nice but most of them are worn out.
   / 50" used Zero Turn vs Tractor with 60" finish observations #6
The hill behind our house is steep enough our zero turn doesn't do well on it.
I use the tractor with 4 WD to mow it.
But for the rest of the yard our 35 HP 72" zero turn will easily out mow our 35 HP tractor with 84" rear finish mower.
As for ride, our Hustler Super Z zero turn rides a good bit better with 7-8 PSI in the turf tires, suspension seat and flex forks vs the tractor has stiff R-4's with 35 PSI in the front tires and 15 in the loaded rears
In agreement with you grumpyJoe. Not so much an either or but to inform those that may have the money to only buy one or space for only one or for those who don't want excess machinery around.
I love my tractor for the reasons you stated. It is a fantastic snow blower and I use it more than I ever thought I would.
   / 50" used Zero Turn vs Tractor with 60" finish observations #8
Sure, not everyone wants more than 1 machine to buy, maintain and store.
And tractors generally do just fine for mowing.
We bought a zero turn for 1 reason, to help cut our mowing time on an 8 acre lawn.
The tractor does everything else, including much of the mowing.
   / 50" used Zero Turn vs Tractor with 60" finish observations #9
If the choice is buy a ZTR or a tractor. It’s tractor for the win. Buying a MMM in place of a ZTR doesn’t make any sense IMO.
   / 50" used Zero Turn vs Tractor with 60" finish observations #10
Was cutting our lawn with B2710 kubota with 72 inch bushhog rfm. Bought bushhog ztr mower with 52 inch deck to trim only. I could cut the lawn in 3/4 the time with the zero turn I could with the tractor and 20 inch wider deck same brand and tractor has hydro transmission. All things considered ztr will out cut tractor as it will whip around trees and such and save a lot of string trimming.
Now tractor will handle slopes and wet ares is not safe on or will not handle and never had to pull tractor out of wet spot for mower but ztr will bog in hurry.
As to noise you should wear ear protection on both. Should wear eye also. As to dust, some of that depends on the exact mower. Our bushhog ztr no problem on debris on operator, our ferris is a problem. Diesel does use less fuel. Tractor can also travel faster from one lawn to another if need be driven there. As to ride, our ferris will ride ever bit as good as our B2710 but our bushhog mower will beat me to death.
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2007 MACK CV713 WINCH TRUCK (A52472)
2007 MACK CV713...
STORAGE FEES (A52576)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
2019 FORD F-150 (A52472)
2019 FORD F-150...
