EverythingAttachments
Elite Member
Rather than posting on our existing thread about the 50" Single Lid Wicked Grapple, I think we will get more specific results related to subcompact tractors by starting this new thread.
I sent an email, requesting feedback, to the customers that have ordered our 50" Single Lid Grapple for B and BX Kubotas with pin-on buckets. In the email, I asked permission to share their replies so I could provide you(TBN) with more info.
The first response I received is from Jim, who installed our grapple and the WR Long 3rd Function Hydraulic Kit on his BX2230:
"I am really enjoying having the Everything Attachments compact tractor grapple. I haven't had it that long, and my use has so far been limited by our tough winter here, but it has proven useful in moving cut logs, broken telephone poles, and brush and debris left from a tornado we had here a year ago. I think a grapple is one of the most useful attachments you can buy, right up there with forks. The ability to grab things and pick them up is a huge improvement over trying to scoop them up with a bucket. An open-ended grapple also beats any kind of bucket grapple since you can pick up objects of any length.
The Everything Attachments grapple is an extremely sturdy unit, while being light enough to be useful with the limited lift capacity of the BX-series Kubota Loaders. In particular, the removable bottom tines save some weight (the tine spacing with them removed has not proven to be a problem in holding a load), as does the one-piece grapple lid. The lid is shorter than the bottom tines, which has not in any way been a limitation to me in using the grapple. With a tractor this small, it wouldn't be wise to grip something only at the far edge of a 50" grapple anyway. With the smaller lid, there is only one hydraulic cylinder, a further weight saving. Also, by just driving one cylinder, cycle time is quick. I timed a cycle from grapple fully closed to fully open of about a second with the engine at full throttle, about 3 seconds at slowest idle. The grapple lid has plenty of closing force, well exceeding the lift capacity of the loader arms in gripping 16+ diameter logs. I am able to pick individual logs off a jumbled pile with the grapple tips, then curl the grapple back and open enough to let the log roll back so it's easier to lift-being closer to the tractor. Since the single lid cylinder doesn't use a lot of hydraulic fluid, there is enough flow left over for other loader movements while the lid is in motion.
The lid opening distance is 30", really nice for picking up brush and other compressible items. You can get a good big bite of brush with it. The difference between what you can get to stay in the stock loader bucket and what you can grab with the grapple is unbelievable.
By substituting better quality steel for thicker steel, more weight is cut off of the grapple and available for payload. I haven't tested the unit to see exactly how many pounds I can lift with it, but 6 to 8 foot telephone pole sections are no problem at all.
Of course, a third-function kit is needed to drive the lid, and the unit I got through Everything Attachments was easy to install and works well. The hardest part was picking up a 12 volt feed for the electric valve. I tapped into the run circuit at the ignition switch. The valve kit includes a fuse, and long enough wires to make the run from the loader valve around to the ignition switch. Definitely a DIY project. No special tools required, and no cutting of hydraulic lines on your BX.
Also highly recommended with any grapple is something heavy (like a box blade) on the back of the tractor. BX's are light tractors, and a good counterweight is necessary to get maximum lift. Without it, you'll quickly find the back end up in the air. It's also a good idea to make sure your hydraulic pressure is up to snuff--that's really the limiting factor in lifting.
I plan to put this grapple to much more use once the weather warms up. I have accumulated a number of brush and debris piles in our ongoing tornado cleanup, and the grapple is the perfect thing to get them cleared. I'll also be putting in some new fence in the spring, and the grapple will be great for carrying fence posts, rolls of fencing and gates."
If you have an Everything Attachments Grapple installed on your B/BX Kubota or other SCUT, we'd love to hear about it. If you do not have one, we would love for you to purchase one and tell everyone about it!!
All of our grapples ship free to a commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
Travis
Travis
