50 hr service
   / 50 hr service #1
RosseauK
KiotiDK40se
Ok I've read so much on the 50 service on here I'm confused. My manual says only to change the hydraulic filter not the oil, but it seems some guys change both. I'm thinking i won't just do as the manual says because it looks like a PITA and expensive to do. Just want to see what the consensus was with dk owners.
   / 50 hr service #2
I don't own a Kioti so I can't give you a definite answer, but I'd call the Kioti dealer and ask what they recommend.
   / 50 hr service #3
I do believe you should change your engine oil and filter and do the same with the hydraulic oil and filters. I see from your profile you have a DK40se, if you are not sure perhaps do as MartianTractorMan suggests, contact your dealer. :)
   / 50 hr service
I was going to change engine oil and filter, hydraulic filter only, perhaps air filter and maybe front axle
   / 50 hr service #5
Yup you read it right it is only required to change the Hyd filter, engine oil filter and oil.
   / 50 hr service #6
Found this post on a different thread. Hope it helps and does not muddy the water. Tried to go back and find the original thread/poster but couldn't so not sure who to credit for it. :)
Posts: 284 Re: KIOTI'S 'Official' posision on 50 hour trans service.
I was given the same information by Terry Coley and Tom Martell last September during their visit. The 50 hours fluids change is required to insure warranty coverage. Considering the possible future warranty repairs you �ay need I recommend completing the schedule maintenance to the letter so there is no debate in the future. 徹ff the record two different Kioti engineers stated they have used NAPA and Tractor Supply Universal Hydraulic in their new tractors. It available locally to the NC factory.
Quote:
Originally Posted by Coyote machine
CORRECTION(S)!!!
Per Kioti's conversation with me today with their customer service rep, I was given erroneous information via voice-mail about the error in the manual. This afternoon I requested to speak directly to the technician who has been at Kioti's No. Carolina headquarters for the last 3 years.
I wanted to follow up with someone who could possibly answer what fluid comes in the HST transmission AND the front axle. I was told the error was on the inside cover page, NOT on the section 7-4 page; which clearly states that the hydraulic transmission and front axle fluids and filters should be changed as part of the routine maintenance of the tractor at 50 hours and again at 400 hours. He also said he could not tell what brand of fluid comes from the factory because Daedong buys from different manufacturers based on quantity and price, BUT the fluid IS a UTF, as is the fluid in the front end. Regarding the front end he said that UTF OR Gear oil could be used but he preferred to replace it with gear oil 80/90 weight instead of using the UTF at the 50 hours service. He further said if something went wrong at say 150 hours he would want to see the service records and if they did not show the trans fluid being changed at 50 hour interval he would kick it off a warranty related claim.
So that is the final report from KIOTI direct.
And please let's not shoot the messenger here- I have given the information I was given from Kioti and said I would follow- up for further clarification today; which I did, and I have now posted those results.
Below is a copy of the email I received from the Technician:
"Per our conversation 3/9/2011 concerning the transmission fluid change interval on your DK40SE, KIOTI strongly recommends that the transmission fluid be changed at 50 hours. This, along with the hydraulic filter change, is to flush out any break in material that may have contaminated the fluid. I hope this answers your questions and enjoy your KIOTI tractor."
________________________________________
David Pettus
Product Support
Direct : (919) 374-5065
Fax : (858) 876-1805
Daedong-USA, Inc KIOTI Tractor Division
6300 Kioti Dr. Wendell, NC 27591
Toll Free : 1-877-GO-KIOTI
Website: KIOTI - run ahead of the pack!
_______________________________________________
__________________
Kioti DK40SE with Cab. FEL, KB2485 Backhoe, Gator Grapple, Pallet Forks, CID snow plow, 6 box blade, 6 rear scrape blade, boom pole, subsoiler, and hopefully more toys in the future.
   / 50 hr service #7
Hmm, my DK manual definitely says Trans fluid: change, which I did. Owner's Manual Part # DH14-001. Bought machine new in Spring of 2010. Could the factory recommendation have changed? I know it was a ***** draining, refilling, and carrying used fluid to recycling.
   / 50 hr service #8
Here's what I'd do: and what I did with my DK-40se/hst at 50 hours. Do the engine oil and filter, do both hydraulic filters and fuel filter. BEWARE! first time filters on most of these machines are a BEAR to remove, so be prepared with a two handle clamp type filter wrench or it could take you all day! I'm NOT kidding. I went to synthetic oil at the 50 hr svc. You need to choose to use whatever works best for you. I'd recommend a high quality synthetic, and stick with synthetic after going to it. Amsoil diesel oil, Mobil 1diesel oil, etc.
Have some hydraulic UTF fluid to replace what gets lost when changing the filters. TSC sells generic UTF which will be fine. That's what I use. And my dealer says he NEVER changes the transmission fluid completely UNLESS the customer requests it OR it has contamination from water or whatever. I probably will change it out at 400hr svc. depending on what the fluid looks like.
Change the fuel filter- it's cheap insurance and NOTHING is more important than delivering clean fuel to the injectors.
Also grease every zerk on the entire machine- there are a ton of them. Use a good quality synthetic- NOT some cheap moly that will harden into cement.
   / 50 hr service #9
Found this post on a different thread. Hope it helps and does not muddy the water. Tried to go back and find the original tread/poster but couldn't so not sure who to credit for it. :)
The quote below is from a conversation between me: Coyote machine, and Kattywumpas, discussing the squeal/whine some DK-40 series HST tractors have been experiencing.
I BTW, did NOT change out my entire HST's fluid, but did change both hydraulic filters, and am now at about 300hours. Refer to my suggestions in a post a few down the page, please.
I was given the same information by Terry Coley and Tom Martell last September during their visit. The 50 hours fluids change is required to insure warranty coverage. Considering the possible future warranty repairs you 杜ay need I recommend completing the schedule maintenance to the letter so there is no debate in the future. 徹ff the record two different Kioti engineers stated they have used NAPA and Tractor Supply Universal Hydraulic in their new tractors. It available locally to the NC factory.
CORRECTION(S)!!!
David Pettus
Product Support
__________________
Please refer to blue text above....
Thanks,
CM
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
