Oil & Fuel 50 hour service oil change
   / 50 hour service oil change #1
J.meyers
OK I am approaching 50 hours on my ck25 and would like to put full synthetic oil in the crank case. Can I use mobil 1 ? What else . I run nothing but premium #1 diesel
   / 50 hour service oil change #2
Nothing but number 1 fuel? Your manual calls for #2 unless you have some extreme weather.
Most mobile 1 is designed for gas engines, I use the M1 5w-30 in my pickup. Mobile's sister company delvac makes diesel specific synthetic. As long as your chosen oil meets the manuals spec for diesel engines and is the right viscosity then it will be good.
   / 50 hour service oil change #3
I was told by two different diesel mechanics to stay away from synthetic oil for my 30 hst for various reasons. Am getting ready to do my 200 hr change I buy all my oil at Tractor Supply. Just dont do what I did on my 50hr change was to add to much oil, just follow the book and dont over think.
   / 50 hour service oil change #4
The enthusiastic inhabitants of the oil and lubricants forum would be more than happy to shower you with their favorite suggestions. Just don't expect data or evidence based recommendations from engineering organizations.
   / 50 hour service oil change #6
The bad press that synthetic oil get's is just myth for the most part. I agree with Woodbeef, go with a oil manufacturer that makes industrial lubricants and specializes in agricultural equipment lile Royal Purple for a full synthetic or Texas Refinery Corp. makes a excellent blend oil with a extremely high TBN.
DO NOT USE MOBIL 1 IN A DIESEL. If you must use Mobil oil the diesel oil that they make for diesels that is synthetic is DELVAC.
   / 50 hour service oil change #7
Use shell rotella T or mobil Delvac in 15/40 dyno, I've been useing rotella in my BIG trucks and my small tractors for many years, you can't go wrong, Both brands are available at wally world.
   / 50 hour service oil change #8
Check your manual, i think it calls for CD or CF rating. The Mobile 1 doesn't have this , but the Valvoline did, so that is what i just put in my CK30. It was $35 bucks for 6 quarts......ouch!
RD
   / 50 hour service oil change #9
This is what I am putting in my CK20 next weekend. I am located out in the High Desert of California. Not very cold in the winter, seldom below freezing for very long, but it gets plenty HOT during the summer. Any problems with this selection?
Specifications and Approvals
Mobil Delvac 1300 15W-40 Super Meets or Exceeds the following industry and builder specifications:
API CJ-4, CI-4 PLUS, CI-4, CH-4, CF/SM, SL
API CF-2
ACEA E7/E5
Mobil Delvac 1300 Super has the following builder approvals:
Caterpillar ECF-3
Cummins CES 20081
Detroit Diesel Power Guard Oil Specification 93K218
Mack EO-O Premium Plus
Mercedes Benz 228.3
Volvo VDS-4, VDS-3, VDS-2
   / 50 hour service oil change #10
Sandlot,
I've used Mobil Delvac 1300 in my CK25 for all of my 3 oil changes I've performed. Although it has been great, I'm considering here soon on my 4th oil change of switching to Mobil 1 Turbo Diesel Truck 5W-40 to see how it performs.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2006 Freightliner Business Class M2 Beverage Truck (A47384)
2006 Freightliner...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
