50 hour service: fluid transfer pump suggestions
   / 50 hour service: fluid transfer pump suggestions #1
Jesser02Ex
Bronze Member
Branson 5220R
It is time for my 50 hour service. I plan to complete the project next weekend. The one thing holding me back is refilling the 9.7 gallons of transmission/hydraulic fluid. I do not want to hold the five gallon buckets to pour in the little hole in the rear of the tractor. (I believe this is a poor design by Branson)
Anyway, are there any suggestions for a decent fluid transfer pump so I can easily refill the transmission?
Ideally I could use it to transfer diesel out of my 100 gallon storage tank too.
Thanks!
   / 50 hour service: fluid transfer pump suggestions #2
If you have a Harbor Freight, Northern Tools, Rural King, Tractor Supply or anything similar near you, they should have one or more options. Most of them have a small 12V unit for $50 or so.
   / 50 hour service: fluid transfer pump suggestions #3
At my 50 hour service I refilled the tranny using a funnel with a long flex neck. Wired the funnel into an upright position and began pouring. Three five gallon jugs plus a one gallon jug.
I would venture to say - most all tractors have a fill setup just about the exact same as your Branson.
   / 50 hour service: fluid transfer pump suggestions #4
I have a hand pump that drops down into the 5 gal pail, with a hose that will reach the fill neck from the ground.
   / 50 hour service: fluid transfer pump suggestions #6
Same here using a hand pump in a bucket.
   / 50 hour service: fluid transfer pump suggestions #7
I just used a funnel and held the (2) 5 gallon pails with spout top to manually fill via gravity feed. Didn't spill, went faster than I thought.
   / 50 hour service: fluid transfer pump suggestions #9
Same here, my 8050 took 3pails, at the farm the Magnums take 11 pails just a funnel if we where going to do a lot, such as out of a 55 gallon we have a hand pump to use.
   / 50 hour service: fluid transfer pump suggestions #10
Hand pump from Coastal Ranch Supply, about 30 bucks, works fine. I agree, the fill spout is ridiculous. How difficult would it have been to put a decent size fill hole there.....:confused2:
1995 John Deere 310D Backhoe (RUNS) (A50774)
1995 John Deere...
2014 Mack CXU 613 Semi (A50514)
2014 Mack CXU 613...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
Wolverine Mini Skid Steer Grapple Bucket (A50514)
Wolverine Mini...
Lot (3) HD 12' Corral Panels (A50515)
Lot (3) HD 12'...
