5 series ?s
   / 5 series ?s #1
shibney
2010 Case Farmall 45 CVT
Thinking of buying a tractor larger than my last 4320, looking at a 5083e limited. I known the 4 series very well but they make so many different 5 series I'm a little lost. Can someone clear up the diff models? I know the 5083 seems like the cheaper one. What does the limited stand for?
   / 5 series ?s #2
The 5083e is not available with all the options that can be configured with the 5000M series tractors.
The M series can be configured with additional transmissions, hydraulic options, heavier electro-hydraulic 3pt, heavier duty transaxle, electronic 4x4; to name a few.
I'm sure that I've left out some other options that can only be offered on the M series versus the Limited machines.
AKfish
   / 5 series ?s #3
Not that it matters but they are made in India.
   / 5 series ?s #4
The M Series are the fancier models, with all the bells and whistles. They have electric switches that do turn on and off the pto, 4wd and the slide levers for the Hydraulics are much easier to deal with and they have a much heavier 3 point hitch with the piston type and not a rock shaft type setup. Basically they are a baby 6000 series. Very nice machine. Also, very spendy as well.
The 5083E Limited is a tractor that is trying to bridge the gap between that tractor and the very plain and stripped 5045 and 55 tractors that are open station tractors.
It gives you a lot of nice features that you won't find in tractors in that price range, like the e pto and a hydraulic shuttle, and a cab. The levers are old school manual types levers that don't work as smoothly, and are a bit more cumbersome to use. Doesn't weigh as much as the M series. But, doesn't cost as much either. It is JD value priced cab tractor.
I just traded my 3520 for one last week. I don't have it yet as they are putting the loader and extra hydaulic outlets on it this week. I hope it will be closer to the size I need for the farm work. I just couldn't get my arms around the price of the M series. It was a stretch to get to the 5083E. I am hoping it will work out okay.
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
