5' rotary cutter
   / 5' rotary cutter #1
Bigcountry75
New holland boomer 20
Any body know if I can run a 5' rotary cutter on my Boomer 20? It looks like I may be 2 hp below the recommended pto hp on the one I'm looking at , is that to much for tractor? Thanks for any info appreciate it.
   / 5' rotary cutter #2
New Holland Boomer 20​
New Holland Boomer 20 Power
Engine (gross):23 hp
17.2 kW
PTO (claimed):16.5 hp
12.3 kW
New Holland Boomer 20 tractor photo
2012 - 2014
Boomer Series
Sub-Compact Utility tractor
Subcompact tractors are engineered for smooth surfaces.
Your subcompact tractor is narrow and has small wheels, which affects the stability and cut of a Rotary Cutter. Few operators find subcompact tractors satisfactory in field work. Ride is too rough, mowing speed too slow.
A 48" width Rotary Cutter will be tippy enough.
   / 5' rotary cutter #3
I had an old JD tractor for years similar in size/hp to your Boomer. I ran a 48” cutter and it worked well. I think a 5’ cutter would be a bit large for your tractor.
   / 5' rotary cutter
Thanks for the answers, I think I better stick with the 4' hp wise as well as weight.
   / 5' rotary cutter #6
It would work on level ground with just a light cut, but anything else would be really difficult. 5 foot mowers can weigh between 450lb and 900lbs. That makes a difference.
   / 5' rotary cutter #7
agree, maybe a 5' lightweight finish mower, but for utility use, would not recommend.
   / 5' rotary cutter #8
I run a 48" brush hog/rotary cutter on my Kubota B2601.
In heavy pasture cutting, it generally does OK in low gear but, occasionally it will bog down. Heavy cover taller than the hood has been cut but, it is slow going and will leave a rough finish due to dull blades and material filling the deck volume of the mower.
On reasonable size material, I can cut faster than I can stay in the seat in the pastures I mow.
You will also need nose weights. On my B2601, the front end is really light on a level concrete driveway. In the pasture, I have had the tractor 'see-saw' to the rearward wight bias.
You will do a lot better with a 4-foot flail but, those are impossible to find where I live. I saw a Victory (Chinese) flail on a 40Hp tractor that would side-shift that looked really good. No way to deal with the weight transfer on our tractors though.
I would check out the Caroni's at Agrisupply before I spend any money.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
43002 (A51691)
43002 (A51691)
Cat TH407C Telehandler (A52748)
Cat TH407C...
