5' Land Pride Finish Mower
/ 5' Land Pride Finish Mower #1
JLoaf
White Co., ARKANSAS
Kubota L3830 DT & B2710
I recently bought a small tractor with a Land Pride AT2560 rear finish mower.
It is a 5' - side discharge mower.
I don't need the mower and would like to sell it. Any guess at the value of this thing?
The original owner of the tractor bought it new in 2002 and the tractor had about 260 hrs on it when I bought it from him. The finsh mower probably has less than 100 hrs on it.
Any input would be appreciated.
/ 5' Land Pride Finish Mower #2
The Land Pride equipment isn't cheap... I'd guess it's worth between $750 and $1000....
Based on being in very good condition.
Of corse I'm just guessing...
Regards,
Chris
/ 5' Land Pride Finish Mower #3
I bought a Land Pride 60" rear discharge two years ago. Paid about $1500 as I recall. Personally I'd consider a side discharge to be of slightly less value. Your opinion may differ of course.
I'd try getting something in the $800 rage as mentioned by cmhyland. Might get more if you wait until April or May.
Thanks for all the input.
I was hoping to get at least $700 for it now - maybe more if I wait till spring?
I'm pretty sure the market will improve as spring approaches.
/ 5' Land Pride Finish Mower #6
what size tractor was that mower on? i have a kubota, 21hp, but i'm not sure it would pull a finish mower that big? i have a belly mower on it now and would sure like to use a rear mower instead.
heehaw
The 5’ mower was on a Kubota B2710 - 27 hp (20 pto hp) .
I have a Woods RD7200 6' FM that I pull with the B2710 with no problem.
I do not know what the lower limit of hp would be to pull a 5' FM?
A guy I know pulls a 5' bush hog with a B21 - 21 hp (16 +/- pto hp).
I've never seen him pull it - but the only tractor he owns is the B21 and the only bush hog he owns it the 5 footer. He says it does fine - I am skeptical.
Finish mowers generally take less hp than bush hogs do. I would think that 21 hp would be ok, but I honestly cannot say for sure.
There’s probably a previous discussion on this subject?
Heehaw,
I sent you a private message with my phone #.
Call me if you are interested in the mower.
/ 5' Land Pride Finish Mower #9
I use my JD4100 Hydro (20HP) to pull my 60" finish mower. never had any problems at all. Of course with the hydo it's easy to slow slightly if you see that the grass is really thick. But never had it stall or anything like that.
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
17601CFL (A59228)
17601CFL (A59228)
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
40' New Container (A62679)
40' New Container...
