5 Gallon Containers
   / 5 Gallon Containers #1
Scotty370
Platinum Member
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
I know this has been covered before, but I searched, and can't find my answer! Since our fine government mandated the slow-flow, auto-close poly-cans, are there any recommendations out their for ones that really work? I've got a couple with the sliding, spring loaded spout-shutoff, that are bound up in either the open or closed position. These things "urinate me off" to no end! Are there any out there that are worth a defecation?
~Scotty (politically correct) 370
   / 5 Gallon Containers #5
not 5 gal.... but works great
i got mine off of CL for $40 I took the nossel thing off the end as it leaked and had slower flow than just sticking the end of the tube in tank.
   / 5 Gallon Containers #6
I take the $7 "slow flow" jugs home, and before filling with fuel of any kind, heat a metal drift puch with my torch and poke a hole where the vent should be.
While the plastic is still molten, I screw a large eyelet into the hole, which forms threads around it.
Once it cools, you have a removable vent screw, which makes pouring a lot easier.
FWIW, I have 6 of these (4 diesel and 2 gasoline), and none of them leak a drop of fuel either...
.02 as always...
   / 5 Gallon Containers #7
Anyone else have the following problem with the slow-flow jugs?
Put an almost-empty jug in the back of the pickup truck for a trip to the gas station on a hot day. By the time I get there, the jug is blown up like a beach ball from expansion of the fuel vapor inside. Pop off the pour cap to release the pressure before removing the filler cap. How safe can a can pressurized with fuel vapor be ?? !! :eek: Shouldn't there be some kind of pressure relief valve on these things?
   / 5 Gallon Containers #8
yeah, and the vapor they are trying to prevent, just came out with force behind it....hmmmm...
thanks big brother!
if i were going to replace my crappy fill jugs, i'd get the style posted above....like jegs....they empty QUICKLY!
   / 5 Gallon Containers #10
you mean like a screw eye with wood threads?
.02 as always...
Komatsu PC138 (A50490)
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
LOT LOCATIONS (A51219)
2022 Forest River Cherokee Grey Wolf 23MK Patriot Edition 29ft. T/A Travel Trailer (A48082)
2022 Forest River...
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
2025 13ft X 20ft Single Garage Metal Shed (A48081)
2025 13ft X 20ft...
