5' fel bucket, addes hooks and teeth
   / 5' fel bucket, addes hooks and teeth #1
spo307
Levittown & Long Eddy NY
kubota L4400
I got a older bucket ( free) added 1/2" 2 x 2 angle to the top and welded on hooks replaced side cut plates with 3/8", added 1/4" plate in between ribs bottom of bucket. welded on shanks with fabco pin on teeth
   / 5' fel bucket, addes hooks and teeth #2
Nice job!!!
   / 5' fel bucket, addes hooks and teeth #3
Lookiing good Spo. You keep welding up these projects, you're going to wear out that welder of yours!
   / 5' fel bucket, addes hooks and teeth #4
Yep, super nice work there!! You're really set up to do some damage with that bucket now. But, please do tell us where you get your buckets for free??? :)
thanks all and yes i did too many project in a short time, i am burnt out ( no pun intended ) i grabbed up the bucket it was to be thrown out due to wear on the bottom thats why i beefed it up with the 1/4" plates
   / 5' fel bucket, addes hooks and teeth #6
Within hours of getting my present little tractor, I voided my warranty when I welded 2-inch angle across the top of the FEL to strengthen it, and to have something sturdy enough to hold hooks.
I can't imagine a bucket without teeth. I move a heck of a lot of snow in the winter -- the teeth are invaluable for cracking ice a few days after the snow is cleared, melted, and refrozen. I move a lot of mulch, stone, and junk. The teeth don't get in the way. I also rip a lot of small roots out of the ground. There is no way I could do it without the tooth bar. Extra plating on the sides and bottom are invaluable.
Great job Spo -- and great photos. Everybody should do what you did if they have a small tractor and FEL that is used for a zillion projects.
   / 5' fel bucket, addes hooks and teeth #8
that loader buddy is neat. Only for kubota it seems?
2006 Capacity TJ7000 (A50120)
2006 Capacity...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
