Traction 4x4 indicator light on RK55
   / 4x4 indicator light on RK55 #1
jayincmh
Bronze Member
Heath, OH
RK-55
I took delivery of my new RK55 last week. As I知 working thru the operation of the tractor...I noticed that the dash has a 4x4 indicator light in it during the start-up illumination of the dash, but the indicator doesn稚 light up when I engage the four wheel drive. Anyone else on here with an RK55 that can tell me if they have a working indicator on the dash for when the 4x4 is engaged, or not? Not sure if it isn稚 working, or that there isn稚 an indicator light for that. Thanks in advance.
   / 4x4 indicator light on RK55 #2
I have RK37 and that indicator does not work however I was told it's because they use the same dash as the RK55 which I would then expect it to work in the RK55
Thanks Chesternator. That was exactly my thoughts.
   / 4x4 indicator light on RK55 #4
I have yet to test 4x4 on mine. Next chance I get, I'll post back with my result.
   / 4x4 indicator light on RK55 #5
Just used 4x4 today on my RK55HC when I ran out of traction, so I know it works, but didn't look for the light. Next time I fire her up I'll check if the light comes on when running 4x4 too.
Thank you, Folks. Much appreciated.
   / 4x4 indicator light on RK55 #7
Just tried it on my RK55HC. No light. Guess the dash light isn’t associated with that circuit for our tractors. Maybe it is on the TYM models.
   / 4x4 indicator light on RK55 #10
I have a TYM T554. No indicator light for 4x4. It is for the T754 which uses the same dash but has a few more “big tractor” features hooked up.
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A48081)
1987 LANDALL 48ft...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
Char-Griller BBQ PIT (A50860)
Char-Griller BBQ...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
