4X20 ROPS Removal
   / 4X20 ROPS Removal #1
sunnyside360
Veteran Member
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
Have a 4320 with 485 BH and must fold down the ROPS to put in the garage. I tried removing the top half of the ROPS by removing the pins but could not remove after taking off the locking pins. Tried light tapping with hammer and block of wood but still no dice.
Is there a trick to removing the pins with the circle clips? Sure would be nice to not have to bother with the ROPS since I don't work on hills with this tractor.
   / 4X20 ROPS Removal #2
* I don't work on hills with this tractor.
Hills aren't the only place to roll tractors.
   / 4X20 ROPS Removal #3
I have the same tractor and had the same problem. I used a hammer and a piece of rod to drive the pins out. They are tight and even harder to put back when you need to raise it again. The pins need a little more bevel on the ends to help get them started back through the 4 holes.
   / 4X20 ROPS Removal
Wayne, many thanks for your helpful response. I don't plan on leaving the ROPS off 100% of the time. Based on your experience, I think I will file the holes slightly and bevel the pins a little more prior to replacing the top half.
Actually, my JD dealer already filed the holes for the pins/holes with safety pin type lock to make it easier to tilt the ROPS when entering/exiting the barn which only has 7.5' high overhead doors.
   / 4X20 ROPS Removal
A rops folds so you can get the tractor in the garage .
So why defeat the purpose by trying to remove the rops ?
Don't make no sense to me.
On the 4X20 series tractor with 485 backhoe, the folding ROPS is very heavy and lays against the BH controls when lowered and could/would damage the levers.
   / 4X20 ROPS Removal #7
If you put the pins back in their holes after you fold the ROPS does it still hit the controls? If not--you could drill a small hole in the ROPS bracket to put a pin in that would hold the upper 1/2 of the ROPS off of the control tower.
   / 4X20 ROPS Removal
Good idea. I'll check it out.
   / 4X20 ROPS Removal #9
QUOTE]
That helped me. Another thing that is aggravating about the ROPs is the height. I have lots of trees to mow under and the ROPS catches limbs that actually make it more dangerous in the up position than when it's in the down position. If it was 12" to 18" lower that would help tremendously.
I guess I'll have to crank up the old chain saw to help that situation.
   / 4X20 ROPS Removal
I considered shortening the ROPS about 12" and the dealer strongly advised not to do that for liability reasons. Also, the tractor trade-in value would be significantly less because the ROPS would need to be replaced prior to re-sale. So, decided to live with it the way it is. I dread the day when I forget to lower the ROPS prior to entering the garage.
2016 Ford E-450 LP Handicapped Bus (A55788)
2016 Ford E-450 LP...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2014 BMW X1 (A55758)
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
