3-Point Hitch 4x20 hydraulic spool change out
   / 4x20 hydraulic spool change out #1
jloven
Bronze Member
Marshall, NC
2013 John Deere 4720, 2014 New Holland T5.115, 2017 JD 4066R cab
I wanted to see if anyone had any advice or experience in replacing a 3 spool valve with a 4 spool valve? I have a 2007 cab 4720 and seem to have plenty of room to remove the current 3 spool valve and add a 4 spool valve like this one (FPS 4:)398 L239 4 Position Manual Hydraulic Spool Valve, New | eBay)
I feel confident about getting a second hydraulic control handle in the cab along with the linkage to control the 4th SCV. I can mount the 4th SCV on the back easily enough. I am just unsure of how the fitment of the larger spool valve will fit / connect to the tractor....Any suggestions or ideas?
   / 4x20 hydraulic spool change out #2
The replacement valve has to match your hydraulics open center system AND your hydraulic system flow, which is 12 GPM.
The valve you linked to appears to be a closed center valve.
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2019 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
