4wd
   / 4wd #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I've used 2wd tractors for some time ( yanmar compacts ) and now I have a NH 1920 4wd.
Question here. Generally around the fame I use 2wd. I have been disking the nort 10ac the last few weekends, and have found that I need the 4wd to pull and turn well while pulling the disc. Here is the actual question... is hte 4wd used just to do the manuver, then you disengage it.. or is it ok to leave it in 4wd for the whole job. ( I.E. while I'm in the dirt discing )
Thanks,
Chris
   / 4wd #2
On all ground engaging tasks... leave it in MFWD continuously... and bring your ground speed up to about 4-5 mph ... for most jobs {as long as your implement is sized to your tractor...}
   / 4wd #3
<font color=blue>...and bring your ground speed up to about 4-5 mph ... for most jobs ...</font color=blue>
To clarify - my brain was engaged in farm tillage implements with the optimum 4-5 mph...
Of course when using your box blades, rear blades, etc. {non-tillage type}... the job will dictate the proper ground speed... /w3tcompact/icons/smile.gif
   / 4wd #4
Like John said, just put'er in 4WD and let'er rip as long as you're in the dirt instead of a hard surface.
   / 4wd #5
I hardly ever take mine out of fwd. I use it when I mow because the ground is so steep in some parts and Iuse it when I back blade. The tractor is so lite I feel better with it in fwd.
Solo
   / 4wd
Good, that was what I was hoping to hear. Leave it in 4wd while working( not on hard surfaces )
Thanks to all,
Chris
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A51243)
2004 TRAILKING...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
2024 CYNERGY CARGO LLC 7' X 14' CARGO TRAILER (A51243)
2024 CYNERGY CARGO...
