4wd vs mfwd
   / 4wd vs mfwd #2
Welcome to TBN:D
It's the same thing, John Deere uses that term (MFWD) instead of 4WD.
   / 4wd vs mfwd #3
I think where people get confused is 4WD, MFWD, of FWA. If my understanding is correct the first two have a transfer case and drive shaft to the front end and the last one (FWA) is usually hydraulic motors on each front wheel. If I am wrong please explain the difference.
   / 4wd vs mfwd #5
WilliamBos nailed it.
A "4wd" is technically a large, articulated tractor with almost equal power to all four hubs of equal sized tire.
An FWA, or MFWD is technically a smaller frame tractor that supplies "assisting" power to the front hubs mounted with smaller tires at a typically 80/20 ratio or thereabouts.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
