4WD Dash Light Not Working
   / 4WD Dash Light Not Working #1
RKJeepXJ
NC
LS R4047H
Anyone elses 4wd light not work? The tractor goes in and out of 4wd with ease and its definitly engaging, the light on the dash just doesn't work. Haven't had time to really trouble shoot it either so it may be something simple.
   / 4WD Dash Light Not Working #2
The 4wd indicator light on my R3039 has never worked. The dealer told me it does not have one, the manual says it does.
   / 4WD Dash Light Not Working #3
The dash is used in other models my 5030 the light doesn't go on either.
   / 4WD Dash Light Not Working #4
From what I understand the dashes are used for several different models some have a light and some do not. My Montana has the spot for a light but does not have the light. Did your light ever work if so it should be simple all there should be is a position switch on the linkage and a lamp, if not it probably doesn't have one.
   / 4WD Dash Light Not Working #5
I didn't realize there might even be a light for that....haven't seen it on the couple of 4041 and 4047s I've run.
This is probably correct. You can see the silouette in the dash cluster but it has never worked. No biggy, you can tell from the linkage position if its in or out.
   / 4WD Dash Light Not Working #7
Mine has never lit up either.
   / 4WD Dash Light Not Working #8
LS uses the same dash on a ton of diff models. Even the ones over seas. Over.there they also havy the electronic 3pt controlls. All my LS's on my lot have the same dash and there is no sensor on the tractor to tell it when to light up.
   / 4WD Dash Light Not Working #9
Mine has also never lit up... makes one wonder on which exact models they do light up on as it seems like no one has one that actually lights up
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
Pickup Instructions (A47384)
Pickup...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
