4th cutting
   / 4th cutting #1
M5farms
Platinum Member
Panhandle
jd 2630 - NH TL100A-35 ferg-53 ford backhoe
Just finished 4th cutting of my 20 acres tifton 85 . averaged 11.89 bales to acre this year. Considering 2 yrs ago it made 39 rolls all yr (I bought it last year.) I made around 100 rolls last yr but after first 2 cuttings this yr I started working on eliminating the Bahia grass in it and this cut there was not one sprig of Bahia . I will sell this cutting as I have all my cow hay put up. Should get my fertilizer money from this yr back on this one.
   / 4th cutting #2
3 bales an acre is a really good cutting.:thumbsup:
   / 4th cutting #3
By stating 11.89 bales per acre is that per cutting or for all 4 cuttings added together? What size/weight are your bales?
   / 4th cutting #4
Joining you in the curiosity on this one.
   / 4th cutting
4x5 bales 900# avg . manor herbicide cheap a effective . i cut 3rd cutting waited 1 week sprayed the fields with manor waited 1 more week then applied fertilizer. Very little chlorosis on the Bermuda. Alot of folks are using roundup to kill Bahia in Bermuda . cut and bale your fields on 4th day spray 12oz per acre roundup the Bermuda is still dormant about 5 or 6 days after cutting. I will use this method this winter . we usasally get a warm-up avfewvweeks a yr and the Bahia will green up so I will spray at these times then use manor during the growing season.
   / 4th cutting
this was season avg. The second Cut was the best I was a grunt over 4 bales to the acre. My baler is a NH br7060. I build the biggest bale it will make and run the pressure around 1900 psi. I don't sell a lot of hay cause I usually don't have any to spare but this year is an exception.
   / 4th cutting #8
Pastora will eliminate Bahia
   / 4th cutting #9
What's the beef with Bahia? I'm trying to get it established in hard to grow poor soil. Took a trip out west a few years ago and it was growing everywhere; side of the road, ditches, unimproved pastures. Have neighbors that use it as their only horse hay source. Why can't B and B co-exist?
   / 4th cutting #10
From my personal observation if Bahia is left uncontrolled in a field of Coastal Bermuda for a long enough number of yrs you will have a very small % of Bermuda because the Bahia will choke it out. I dislike Bahia because once it's cut it will turn darker in the bale than Coastal PLUS on the fields I've baled I think Bahia will not produce the same tonnage per acre as Coastal Bermuda.
Levee Plow (A50860)
Levee Plow (A50860)
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A48081)
2015 Ram 1500 4x4...
2022 Massey Ferguson 1825E 4WD Tractor (A50860)
2022 Massey...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2015 Ford F-550 4x4 Knapheide Service Truck (A48081)
2015 Ford F-550...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
