4H Lamb Equipment
   / 4H Lamb Equipment #1
PetersonQH
Northwest Central Ohio
Anyone on here have any plans for equipment used to show or excercise 4H lambs. My son has decided to do lambs for 4H, instead of horses that we already own...I am looking for plans for a "lamb chariot" and blocking stand if anyone has them? If not I could use pland for the mechanism used for holding their heads while on the stand.
   / 4H Lamb Equipment #4
I had lambs in FFA. We made our own blocking stand. Don't have plans, but it was extremely simple.
Wood base was made of appropriate size from tongue and groove material, but any solid wood would do. I'd avoid plywood or chip board because this tends to be out in the weather and you don't want it coming apart.
Legs were made from 4 lengths of metal pipe.....maybe 3/4 or 1 inch, don't recall. One end of the pipe was threaded and it screwed into a threaded flange that was bolted to the wood base. This allowed portability by simply unscrewing the 4 legs.
Similarly, there was a threaded flange for the neck stanchion bolted to the top at the front. A short length of threaded metal pipe screwed into the flange. A smaller metal pipe with a rebar yoke welded on top of it slipped into the pipe. Height was adjusted by passing a pin thru any of several holes drilled into the yoke pipe. There was a rope/leather catch that went on top of the yoke to restrain the head/neck in the yoke.
Lengths of the pipe were not critical, but selected to match size of sheep and height of student to allow working on the animal with minimal strain on the student.
STURDY, simple to assemble and transport.
Hope this helps.:)
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2016 Chrysler Town & Country Van (A51694)
2016 Chrysler Town...
