if you can lift about 65#, you don't need a lift or hoist.
you take the seat off
you pop the pins out of the 3pt knuckles and toplink yoke. 99% of the time.. that part right there.. getting the pins out.. is your biggest deal. use lots of penetrant oil.
remove the perimeter bolts on the top cover, don't remove the inner bolts.. yet.. they hols the cyl to the top cover.
the cover almost lifts straight up, but easier to lift front of cover first and start coming up with it, then move forward a hair, then up.
you will have a long arm hanging down. it freely fits in and slips out of a control valve on the pump. ( during reassembly, you remove the inspection cover so that as you lower the top cover in place, the little control arm has to go into the slot on the control valve. ) the inspection cover gasket can be rtv'd.. but all other gaskets must be clean n dry.
there will be a top cover gasket, a 2-3" oval gasket under the cyl, and 2 dime sized gaskets under the cyl.
the old gaskets must be cleaned off. i use a razor blade, spray carb cleaner and then a scotchbrite.
remove cyl.
use an air hose with a rubber tip to pressurize the oil hole on the underside of the cyl a bit, hold your other hand with a rag in it cupped to recieve the piston that will be shoooting out.
don't air it like you are firing a howitzer shell.. just a few psi will pop it out.
if it's a 3 ring steel piston.. set aside and get the new naa oring and backup washer piston.
take a brake hone to clean up the inside of the cyl.. even if it looks immaculate, which they seldom do.. at least put a crosshatch on it. if it is scratched.. just run it around till at least sharp edges are cut down. the CNH oring is beefy.. you can actually hone that cyl past it's book tolerance and still get a good oring seal.. thus, if honing the scratches and you can get them out with a little extra.. go for it.
clean the bore out good.
install backup washer then oring. lube them well to help get them on.. a spoon helps witht he leather washer after soaking it.. and don't roll the oring.
a light chamfer with a rat tail at the mouth of the cyl assists in insertion of the piston without cutting the oring. lube it before insertion.. grease.. oil.. etc...
domed end in.. oring should be the first entering, backup washer last.
dogbone rides loose in the cupped end of the cyl
new dry gaskets.
easy peasy.
if you do the relief valve.. just reach in.. it unscrews like a spark plug.. etc. you will be reaching around the pto shaft.. but with top off and side cover open.. it's no problem. you can actually change it from the side cover alone with stubby wrenches, or long wrenches torched to put a lazy bend in them. BTDT.. all 3 ways are no sweat...
