49.5 HP 2WD tractor independent PTO continuously runs ,when PTO clutch is disenged
   / 49.5 HP 2WD tractor independent PTO continuously runs ,when PTO clutch is disenged #1
Ranjan
india
new holland
when the PTO is engaged , it should stop when the independent PTO clutch is disengaged, but it keeps running and its RPM matches with the engine RPM.
   / 49.5 HP 2WD tractor independent PTO continuously runs ,when PTO clutch is disenged #2
It may be turning, but not delivering any real power. just drag.
Or
There could be internal corrosion that is locking the shafts in spite of the clutch. gear engagement.
Or
The pto drive and or clutch may be broken
Start by attaching some pto driven implement and testing to see if the drive is transmitting power constantly
   / 49.5 HP 2WD tractor independent PTO continuously runs ,when PTO clutch is disenged #3
Or the pto clutch plate may be rusted/stuck to it's flywheel...
IF it's not just "dragging", my guess is the clutch plate is rusted/stuck...
SR
Takeuchi TL8R2 (A47477)
Takeuchi TL8R2...
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2017 Chevrolet...
New/Unused Wolverine Skidsteer Trencher (A54865)
New/Unused...
2022 ELECTRIC MINI SKID (A55745)
2022 ELECTRIC MINI...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
