48" vs 60" deck - which is better for a wooded, hilly lot?
   / 48" vs 60" deck - which is better for a wooded, hilly lot? #1
KYKub
East KY
Kubota - BX 1860 and G1900
Hello. Recently acquired a G1900 4WS with a 60" deck. I love the tractor--in great shape and runs and operates smooth--but was disappointed in the traction on my wooded, hilly lot. Granted, it was pretty wet when I tried to mow on a warm day after some really cold days (=pretty moist conditions), but, still, the machine just seemed too heavy too pull a fairly steep hill that, by comparison, my Cub Cadet lawn tractor with turf tires pulled pretty well (as long as I leaned just right in and over the seat!).
I mow about 1 acre regularly.
I have loaded tires with fluid. and am ordering new ag tires and hope that helps.
The 60" deck is a monster and I'm wondering if dropping to a 48" deck might make the tractor lighter and a bit more agile. Anyone have any good information on this? I have my eye on a 48" deck I can probably get for $250 or so.
Thanks for your input. Jeff
   / 48" vs 60" deck - which is better for a wooded, hilly lot? #2
Are you mowing with the deck on the ground, pushing through the grass and riding on the wheels or is it up slightly keeping the weight on the tractor?
Hi ruffdog. I was running with the deck on the ground. I think that is the intended procedure. Rollers cut into the ground in several places and slipping tires was a problem. Would it damage the hydraulic system if I constantly run the machine with the hydraulic system "lifting" the deck? (the 60" deck weighs 270 pounds!)
Any opinion as to whether or not the 48" deck might be an improvement?
Thanks again. Jeff
   / 48" vs 60" deck - which is better for a wooded, hilly lot? #4
We have a 60" deck but I would be very happy with a 54" in tight places and to give us a more trailer options. Between 60 vs 48 I would now go with the 48" I expect.
Thanks, Gale. I know what you mean about trailer options - a 60" mower means you need at least 63" clearance, which means anything 5' wide or less won't work. My own solution was to modify (generous description, actually cut the sides off) my own 4' steel trailer to let the deck hang over both sides. Not a job I'm particularly proud of, but it works and I don't plan to trailer often.
4WS makes maneuverability pretty good, even with the 60" deck, but do you think the weight difference with a 48" deck would make any appreciable difference with traction?
Jeff
   / 48" vs 60" deck - which is better for a wooded, hilly lot? #6
Jeff I really do not know but I do not think the weight difference would be a functional factor.
   / 48" vs 60" deck - which is better for a wooded, hilly lot? #7
I like small decks, but rubbing any deck on the ground is going to give you too much drag to overcome.
   / 48" vs 60" deck - which is better for a wooded, hilly lot? #10
I thought the wheels were just to tag on un level places so a not to gouge the lawn? I know with a zero turn they will mess up with the control if they are carrying much weight on the deck wheels.
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
