4720i power steering cylinder removal
   / 4720i power steering cylinder removal #1
toby873davis
Branson 4720i
Hello,
I have a 4720i with a leaking left front cylinder. I can not reach the two bolts that are on the top plate? I am so stuck that I have started to remove the front assembly, battery, and battery plate. It appears that may still not get me access. I am so stuck I am beginning to wonder if they are designed to be repaired in place. thank you ahead of time.
Ok,so this is what you do. Drop the front axle but removing the four 19mm bolts, jack up front end 2 -3 inches. Lots of access. Or, you can remove everything else over two days until you just remove the four bolts. Pretty sure I could replace the cylinder in about 30 minutes now. Hope this helps someone with a leaking steering cylinder.
Toby
   / 4720i power steering cylinder removal #3
Thanks for sharing! Glad you got it off and on your way to it being fixed!
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
12 in Small Excavator Bucket (A52377)
12 in Small...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2012 International 4300 Reefer Truck (A53472)
2012 International...
