4720i 4x4/loader/shuttle problems
   / 4720i 4x4/loader/shuttle problems #1
calbug
Bronze Member
Georgia
Branson 4720i
overnight, tractor has no power, like the brakes are stuck. even low range 1st gear it wouldn't climb curbing (6" slab) to park in shed. almost seems like the clutch is slipping, but it doesn't whine or anything. i usually take off in 2 range 1st gear if i'm traveling somewhere but now it won't budge. recently serviced and fluids are full. no noises or anything that appears to be out of the ordinary. engine revs up good. had to rev to 3000 rpms today just to pull onto trailer in lowest gear. clutch adjustment maybe? advice is greatly appreciated.
   / 4720i 4x4/loader/shuttle problems #2
Speed of the tractor should be proportional to RPM and gear selected. If the speed is less your clutch is slipping. Check the play of the pedal. If the speed is proportional to the RPM and gear selected and the tractor labors to move something puts a load (such as stuck brakes) on it. Try to move in reverse short distance in attemp to free the brakes.
Valvoline Brake Fluid (A53117)
Valvoline Brake...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
40 ft. Shipping Container (A53117)
40 ft. Shipping...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
