4720 run a bush hog 307?
   / 4720 run a bush hog 307? #1
tbd24
i have a 4720 and i want to run my old bush hog model 307 7ft rotary cutter. its currently a 3pt hitch, however i can swap out the rear height adjustment arm with a piston and run it semi mount. so i want to know if this would be tough on the tractor turning that beast. i don't plan on mowing anything heavy with it, about 1.5 ft of grassy fields and some golden rod in the fall. TIA
   / 4720 run a bush hog 307? #2
Should not be a problem if it is Cat 1 and you have enough front end weights.
The tractor has enough power no problem.
Steve
   / 4720 run a bush hog 307? #3
I agree. Shouldn't be a problem at all.
   / 4720 run a bush hog 307? #4
Yeah, you might wanna get some weight for the front. I used my 4520 with a 6' KK 3-pt. brushhog the past two weekends and had some trouble turning on the hills. I already have filled fronts but I think I'm gonna get a few weights to hang on the front too.
-Dave
   / 4720 run a bush hog 307? #5
i have a 7 foot hardy on the back of my 4720 now. also use a 8 ft. pull behind , not at the same time tho. j.k.
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
UNUSED EINGP MSC2030F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A55787)
2003 Komatsu...
2019 Ford F-550 4x4 Terex LT40 40ft Insulated Bucket Truck (A55788)
2019 Ford F-550...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
