471 Massey Ferguson
/ 471 Massey Ferguson #11
kmanvt;
23k for the 471 w/shuttle, 5.5k for loader and bucket, and 1k for pallet forks...
the NH's and JD's were considerably higher. you have to keep in mind that the 3-number series MF's are made in Brazil, which makes the price difference. the 4-number series MF's are made in France and are much more expensive..
and, out of curiosity, what quotes did you get on similar NH and Kubota tractors?
SM
/ 471 Massey Ferguson #12
(Both quotes was for the ROPS model and included canopy, engine block heater, grill guard, & extra set of hyd. ports)
Below is the best price I got for both.
NH TN75A Standard with 32LC loader w/ QA heavy duty bucket - $29900
Kubota M8200 with 1251A loader w/ QA bucket - $30300
If I remember correctly the MF quote I got was either the 471 or 481 and it was $33K (same setup as above).
/ 471 Massey Ferguson #13
The MF471 takes the MF1070 loader with a 3100 lb lift capacity (full height/bucket edge) while the TN series takes the 32LC (current loader) with a lift rating of 2600lbs.
The MF lifts almost 20% more. The tractors seem to be about equal or close in price with the MF getting the Perkins and a combining valve option (for adding 3pt hyd power to loader and other implements).
The 3pt hitches are about equal and the MF has less tranny options
The TN75A a bit more stylish and 5730 lbs .
The MF 471 a bit heavier (4wd) at 6000-6305 (depending on brochure)
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2017 FREIGHTLINER CASCADIA SLEEPER (A59906)
2017 FREIGHTLINER...
Case SV280B (A60462)
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
