470 buck
   / 470 buck #1
tractorguydave
Water Valley,Alberta
Satoh Buck 470d
Hi , I have a 470 Buck that I bought in very rough condition ,but the price was right. It came with a GB front end loader. So far I have replaced the front ag tires(they were completely worn out and wouldn't hold air)fixed the steering box broken bolts (because it had been rolled) fixed the plastic dash. I upgraded to a gm alternator and rewired it (a lot of the original wiring was either broken or rubbed through) I just picked up a hydraulic pump from Princess Auto and my next project will be to retrofit it into my buck when I have time
   / 470 buck #2
You can run that pump from the front crankshaft using a U-joint and suitable support.
Have run one on my Mitsu for about 12 years.
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
