Snow 47" snowthrower broke
   / 47" snowthrower broke #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
This stuff only happens when I have 16" of snow in the driveway!
I drove my 2305 out of the tractor shed, engaged the PTO for the front mounted snowthrower, and noticed that the auger and impeller weren't turning. I shut off the tractor and got out to see what was wrong, and saw the large sprocket from the snowthrower lying on the ground behind the tractor. :eek:
Fortunately I could get the tractor into a heated garage to work on it. Although I never found the woodruff key (had to drive into TSC to buy one), I think the set screws loosened and allowed the sprocket to slide forward off the shaft.
I put the sprocket back on the shaft with a new woodruff key, adjusted the chain tension and tightened the two setscrews using red loctite.
   / 47" snowthrower broke #2
at least it was an easy fix. i had a similar problem w/ my garden tractor blower, set screw loosened, key fell out, shaft was spinning on the gearbox. never fun working on it when it's 15F, and i don't have a heat option!
   / 47" snowthrower broke #3
Glad it was only labor and nothing really broken....but what a pain. I filled the tractor the day before for the storm, after it was over went out ready for some great seat time w/ alot of snow. Saw I left the key on ALL night:ashamed: Oh my god will it start or like you for the worst snow storm of the season, I will not be ready....turned the key slow turn over, but it did fire up Thank my lucky stars....and off i went. Better double check that key next time.
Yep, all it took was time (and a trip to TSC for a 99 cent 1/4 X 1-1/4 key). I will be checking the setscrews more often from now on!
fdmars:
Glad it turned out OK. I haven't left the key on, but I HAVE started driving forward with the block heater plugged in. Fortunately, I noticed the extension cord straightening out and stopped in time!
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
