47" Snowblower Question #2
   / 47" Snowblower Question #2 #1
Wyobuckaroo
Platinum Member
NW BC CANADA
John Deere 2032R
My question is.......
Will a 47" snowblower bolt onto the attaching hardware for a 7-8-955 series tractors ?
I have an older 855, and know where to get the attaching hardware, and drive shaft. Just need to know if the blower body will mount properly.
   / 47" Snowblower Question #2 #2
Don't believe it will, but call your JD dealer and they will tell you for sure. Maybe there is some type of adapter?
Scott
   / 47" Snowblower Question #2 #3
Wyobuckaroo (good user name)
If you go to the John Deere Web site and to their Parts Catalog and do a search for model 855 it looks like the 655,755 and 855 CUTs are groupled together. Next, choose Attachments, then 47 inch snowblower, then sectional Index where you'll have to select 655,755 and 855 once again..........wheeewww............ at that point it will show groupings like the Front PTO shaft, Hydraullic Lift Cylinder, Front PTO Attaching Parts and Mounting Bracket and Hardware...any differences between model numbers will be annotated in the "Keylines" or parts listing. Be sure before you print, to select "Illustration + Keylines" for each of those areas (over to the right in print selector window), from there you will be able to see if it's a direct match......
Very simple after you've mastered using the JD parts Catalog, no need to contact the Dealer, they'll do the same thing...............:thumbsup:
2019 DODGE RAM 2500 HD SERVICE TRUCK (A51406)
2019 DODGE RAM...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2016 Freightliner M2 106 Cab and Chassis Truck (A52377)
2016 Freightliner...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
