47" front mount snow blower
   / 47" front mount snow blower #1
bones72
Jd2210
Slip joint on drive shaft go to front or back? Does phasing shaft do any thing for vibration?
   / 47" front mount snow blower #2
The slip yoke goes toward the front. Yes U joint phasing helps a little but the shafts with the CV joints help the most.
Thanks for info. Best place to buy shaft with c.v.joints. U have any luck greasing H.S.T. shaft with needle adapter
   / 47" front mount snow blower #4
I found both shafts on eBay a couple years ago. I made a mid shaft with a automotive CV joint about 6 years ago used it for a few years then bought the Deere one. Mine actually works better and I shouldn't have bought the factory one. Now I have 2. The one I made is up for grabs if anyone is interested in it? Local pick up in CNY.
I've tried greasing the engine shaft with a needle adapter but have had better luck removing the floor pan, rops and rear fender. I think I'm going to try getting to it again from under the tractor in a couple weeks when I'm on vacation. I'll let you know how it goes.
Thanks for info. Sounds like you have mechanical experience. I live north of International Falls Mn so dealers not readily available. I grease HST zero with all removed but question if it is taking grease. 500 hours on 2210 and shaft looks good who knows?
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2016 Kubota RTV-X900 4x4 Diesel Utility Cart (A51691)
2016 Kubota...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
