4610SU rear axle clunk
   / 4610SU rear axle clunk #1
ETD66SS
Platinum Member
Newfane, New York
Last weekend I was doing some brush hogging, I normally wear ear plugs when doing this, so don't hear some sounds. When I got done I parked the tractor for the day. A few days later I wanted to move the tractor as well as disconnect the brush hog.
I didn't use ear plugs because I was just moving it a short distance. When I started driving, not only did I hear a clunk in the LH rear axle, but I could feel it as well. It was a pretty good metallic clunk, once per revolution of the rear tire. I was driving with the brush hog's rear wheel down, I thought maybe that was it, so I lifted it completely off the ground, that didn't resolve the clunking sound.
Next I tried engaging/disengaging the differential lock, still hear/felt the clunk. Then I slammed on the brakes a few times, still had the clunk. I drove to where I wanted to drop off the brush hog, so I removed it and did a test drive, the noise was gone.
I don't think this was a noise that had anything to do with the brush hog, the PTO was off, and it didn't feel/sound like a noise coming from the lift arms or anything like that.
I can't replicate the noise now, and I guess it has me a bit freaked out as to what it could be. It really did sound/feel like a deep mechanical/metallic clunk coming from the LH rear axle housing.
Any ideas?
   / 4610SU rear axle clunk #3
So it did it with the bush hog attached and then didn't do it after unhooked? Could it have been your PTO was turning just a little bit making the bush hog turn a little bit and when the blades got to a certain point they were clanging? I've seen it happen on other tractors. That's the only thing I could think it would be since the noise was gone when the bush hog was gone.
Yeah, I will first check the rims. I did check to see if it was the blades on the brush hog, but they were not moving.
But yeah, I was not able to replicate the noise once the brush hog was off...
I certainly did not beat on the tractor at all the last time I used it, there were no "incidents". So hoping it is something simple.
   / 4610SU rear axle clunk #5
Rick is right, check the hardware for a loose bolt etc. The extra weight of the hog could be enough to cause the shift/clunk on a wheel. I had a similar issue years ago and swore it was internal. Turned out to be under torqued bolts on the ez adjust rims of mine.
I finally got the time and weather to check center disc bolts, many of them were loose. So thanks for the tip.
Now, is there a better type of nut to use so they don't come loose? Can I use nylock nuts or deformed head nuts? I don't see why not...
   / 4610SU rear axle clunk #7
Unless the hardware or disc/rim loop is damaged, properly torqued bolts will stay tight. If there is damage, they won't stay tight regardless.
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
