skidoo
- Joined
- May 24, 2007
- Messages
- 323
- Location
- Montana - Growing Zone 5
- Tractor
- JD 2520, JD X749, JD110TLB
So, I am considering either a 46 BH for my 2520 or a 485 BH for a 4520. The 4520 has the top & tilt, so it will be much easier to change 3ph implements than the 2520 along with better control of them. With the BH on the 4520, that nice TNT function would effectively out of service. With the BH on the 2520, it could stay there for longer periods while I use the 4520 to quickly swap other implements. Considering that the two BH's have different capabilities (significant or not?) and maybe connecting it or disconnecting it would not be a big deal, I am not sure which is the better way to go.
If you were in a similar situation, what would you get, the 46BH for the 2520, or the 485 for the 4520 and why? This assumes that you would have both tractors available to you regardless of which choice you made.
