Oil & Fuel 455 Transmission oil leak
   / 455 Transmission oil leak #1
Jason B
Bronze Member
Ontario Canada
John Deere 425( soon to be 455)
Hi Guys
I am having trouble with the transmission on my 455AWS. The tractor moves and works great but there is an oil leak coming from it that I can not find. The oil does not leak from the transmission when it is running or cutting grass but when parked sitting in the shed. The transaxiel oil was recently changed, but I don't think that is where the oil is coming from. Any suggestions as to what it could be. The leak is on the right side of the transmission looking from the back. I am not sure what it is as all the bolts are tight. I will probably be taking it to the dealer tommorrow. Take Care Jason B
   / 455 Transmission oil leak #2
The leak is probably coming from the seals at the point where the actuator rods enter the transaxle on the side you have described. Follow the forward and reverse foot-pedal linkage through their mechanical connection from the foot pedals back to where the actuator rods enter the transaxle on the right side. This transaxle is known to leak from this point after years of normal service. You might consider some type of additive to swell the seals, as a temporary fix. Mine is just starting to weep slightly, and after talking to my dealer (costly$$$), I think it will become a winter project when it needs to be corrected. Craig
Hi
Thankyou for your help. I took the 455 to the dealer this morning. They are going to( hopefully) fix the problem. Other then that, the 455 has been great in the short time that I have had it. Take Care Jason B
PumpJack Brand Pump Jack (A55302)
PumpJack Brand...
New/Unused 13ft X 20ft Single Garage Metal Shed (A54865)
New/Unused 13ft X...
NEW  STARTER (A55745)
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
2017 CATERPILLAR 415F2 BACKHOE (A52706)
2017 CATERPILLAR...
