4510 fuel filter bleeding
/ 4510 fuel filter bleeding #1
yanmars
Veteran Member
I broke the fuel filter bowl. I could not find in my manuals the procedure to bleed the line after it is fixed. Also how much torque is the flange given when tightening?
/ 4510 fuel filter bleeding #2
The torque is hard to say, I usually tighten it by hand and then just a little snug with channel locs. When bleeding the line be sure the fuel bowl is full, then above the injection pump there is a little valve with about a 1/2 to 3/4" diameter knob, open that valve, start the tractor , and after it is running smooth close that valve. That should get the job done.
Thank you for the assistance.
To lawallstractor: That worked well. It is up and running although still too warm. Maybe I will have to relocate the battery etc. Thanks
1992 Polar 307 SS T/A Insulated Chemical Tanker Trailer (A64194)
1992 Polar 307 SS...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2021 Mac Trailers T/A Walking Floor Trailer (A64556)
2021 Mac Trailers...
2003 Ford Winstar (A64557)
2003 Ford Winstar...
2014 BMW 435i Convertible Coupe (A64557)
2014 BMW 435i...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
