4510 3PH Won't Lift
   / 4510 3PH Won't Lift
Re: 4510 3PH Won\'t Lift
Checked the fluid cold today and it was low. Added about a quart and it works great again. I sure was relieved I did not have to dump it and replace the filter.
Redman
   / 4510 3PH Won't Lift #12
At about 150 hours on my JD4700 I was discing my father's garden and was about finished when I came out of one end and tried to pick up the light 16x16 disc I was using and it would not raise. Disconnected and at idle it would still not raise. Eased the throttle up and at about 2100rpm it finally raised. Fluid level ok. Took it in to be worked on under warranty and they found that some screen had come loose and travelled through to the loader scv's. Everything O.K. now. I'm releived.
White Metal Roof Panels (A55758)
White Metal Roof...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
DEUTZ MARATHON...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
