45 hrs and oil still clean?
   / 45 hrs and oil still clean? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
My New Holland TN70A (3 CYL Turbo Diesel) has 215 hours. I bought it used at 170 hrs. Changed the oil and filter. Oil is still as clean as the day I changed it. I thought it was supposed to turn black real fast. Anything I could be worried about?
Bob
   / 45 hrs and oil still clean? #2
You aren't working it hard enough? If that's a worry.
I will try to work harder :D !
Bob
1500 average RPM and 2300 max (for 30 seconds at a time). Mostly 1500 rpm (max torque at 1400 rpm).
So, I need to run at 2200 RPM for a few days?
Bob
   / 45 hrs and oil still clean? #5
I checked the oil in my Kubota with 32 hours on the oil it still looks almost clear on the dipstick. I use the pink off road diesel (500 PPM + sulphur) and that is supposed soot up the oil too.
   / 45 hrs and oil still clean? #6
My first post was a grin. The RPM is not the determiner of work on a tractor diesel, it is the torque demanded by the load. The "throttle" on a tractor is really the governor control which sets the RPM. That control then controls the "throttle" as we normally think of it.
You may not be loading high enough to generate soot or your engine could have very good piston rings and is not passing any soot past the rings to get into the oil. I would not worry about it.
   / 45 hrs and oil still clean? #7
Ahh well; just for interest sake pull the drain plug and change oil. Then tell us if it's still as clean and clear as the day the oil was put in!:D
   / 45 hrs and oil still clean? #8
Bob
color does not mean anything with oil.
   / 45 hrs and oil still clean? #9
Bob
Thats not right at all Bob....:). If you'll bring it to me I can get the oil blackened up for you good....LOL
   / 45 hrs and oil still clean? #10
Right at 24 hrs on mine...and when I take a drop from the dipstick..and a drop from a fresh bottle of Kubota 10W-30 oil...put side by side on a piece of white paper...cant see a bit of difference!
1274 (A50490)
1274 (A50490)
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
Freightliner Tender Truck (A55301)
Freightliner...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
