445a ford 4wd gear
   / 445a ford 4wd gear #1
pete holcomb
super a farmall
I looking for a gear for the 4wd on a 445a the NH dealer says its obslete the part # is E3NN7Z115A any help is apperciated
   / 445a ford 4wd gear #2
If you haven't found it by now, here is the replacement that is supposed to work. Substitute the following: E3NN7D109AC > 83946832 Gear $588. AND C5NNN729A > 81801867 Bushing $10.55
   / 445a ford 4wd gear #3
Hi Tractor Tech, I have a Ford 4610 4WD and I also search for the gear E3NN7Z115AC. On the internet I seareched for it with all your part numbers but i did not find it. Where did you find it?
All the best from Germany, Maximilian Bockhorn
   / 445a ford 4wd gear #4
Max, here is the progression of substitutions that I described when plugging the E3NN7Z115AC (32 tooth for 8X2) into Partspring website. I have not inquired if that gear is actually available, but it looks to be so. Also, the bushings come with the gear.
Also, look at Joseph Industries for purchasing as well: *- Joseph Industries OR in your case of being in Europe, look at a Carraro transmission/axle resaler as another possibility for purchasing.
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
MURRAY 22" 2N1 SELF PROPELLED GAS PUSH MOWER (A51248)
MURRAY 22" 2N1...
New Holland C345 (A50123)
New Holland C345...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
