4430 Clutch
   / 4430 Clutch #1
EYoT
Loyal, WI
John Deere
After adj. 4430 clutch quad range with the sp. tool, the transmission clutch continues to spin after pressing down on levers. Removed and checked all parts and disk thickness, all looks good. Is this normal?
Pto clutch seems to be correct.
   / 4430 Clutch #2
:welcome: to TBN
Don't have the service tech manual, but someone may be along shortly to help you out.
A bit more info about what has transpired may be helpful to come up with the right answers for you.
Don't give up, as there are a lots of knowledgeable members here.
   / 4430 Clutch #3
:welcome: to TBN
Is it possible that the clutch disks are warped. Has clutch operating sleeve had new seals installed? Did you check clutch valve operating pressure?
   / 4430 Clutch #4
Do you mean to say that you split a John Deere 4430? Pretty impressive.
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A51692)
2018 Ford F-250...
