440v 3 phase in residential shop
   / 440v 3 phase in residential shop #1
OutbackL130
chickamauga
L130, 420
Just bought a scotchman ironworker. It is 3 phase 440v. How do I make this work in my residential shop? I also bought a pines bender which is 3 phase 220v which I plan to run off a rotary phase converter.
I plan on adding a 3 phase bridgeport, lathe and squaring shear down the road.
   / 440v 3 phase in residential shop #2
Going to have to have 3 phase from your electric service to start with. Usually its 2 phase. See if you have three transformers on the pole.
   / 440v 3 phase in residential shop #3
I have a neighbor that auctions. He often has food processing equipment that is 3 phase and he cannot test it due to that. So he came to me. Knowing that he needs a phase converter that can be moved around to different equipment I think I will build a rotary phase converter in a roll around cabinet that is simple to operate. I will have to make it large enough for probably a 5hp motor. This will keep him from running wires allover and handle a few different sizes. Thought I might toss an idea like that to you incase it works for you. If you desire something more permanent might look at VFDs.
   / 440v 3 phase in residential shop #4
Can the ironworker be changed to 240v 3-phase? If so, it makes things lots simpler.
If not, it is probably still cheaper to get a dual voltage 3/phase motor for it and either run off a rotary convertor or vfd.
If it is 440 only, you will need a step up transformer after you make the three phase.
   / 440v 3 phase in residential shop #5
Whoops missed the 440. Hope it's dual voltage.
   / 440v 3 phase in residential shop #6
what is the HP on the motor?
   / 440v 3 phase in residential shop #8
I'm running this 35 ton Scotchman, a 50 ton Scotchman and a 15" X 54" Cincinnati Hydra-shift Lathe on a static phase converter that I built for $45. in parts.
With a static converter you lose 1/3 of the power so a 3 hp motor has only 2 hp. With a rotary converter I believe you get full hp but they are a lot more expensive.
I think if I power up one of my machines and just let it run it will act as a rotary converter for another.
If you google you can find instructions on building your own and it's a lot cheaper.
The Ironworker should have dual voltage, 220-440. Not sure what all you will have to change. Probably motor wires (should be a data tag on it) and relays might need different heaters.
My machines run very well on single phase converted. BUT I have been told that I am full of sheet! You can't get 3ph from 1 ph! I just laugh.
I have talked to Scotchman on the phone and they are very helpful with info. You might call or email them.
   / 440v 3 phase in residential shop #9
The big question is, if you have 3 phase nearby. If yes, you are in good shape. If you don't, then you can build your own power plant for what they want to run it.
I run a 35 hp rotary convertors in my shop and it works good. We are looking at putting in 3 center pivot irrigation systems and need 3 phase. It doesn't look like we are going to get it, so we will use convertors.
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2023 FORD F750 CAB & CHASSIS (A53426)
2023 FORD F750 CAB...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
