4400 3 pt won't stay up
   / 4400 3 pt won't stay up #1
Mike_S
South of Kansas City
JD4400HST
4400 3 pt won\'t stay up
Dr. Deere or anyone else that has had this problem--seems like it has been mentioned before, but could not locate the thread. This is my second 4400 HST and it has been flawless in operation until yesterday when it reached 50 hours. After 10 hours of loader and boxblade work yesterday, the rear blade will not stay up for more than 15 minutes after the tractor has been turned off. Until now, the rear blade would stay up for two weeks with bleeding down. While the tractor is running, the blade will drop an inch and there is a hissing sound and the rear blade goes back up and a few seconds later it drops an inch and the hissing sound comes back. It has 50 hours on the meter, so it is time for me to change hydro fluid, filter, clean the suction screen and the small screen beneath the seat. It is my hope that it is not serious enough to have to split this tractor apart like happened to my previous 4400. Otherwise, this 4400HST is great--this is its first little problem! Any thoughts on this little problem???
   / 4400 3 pt won't stay up #2
Re: 4400 3 pt won\'t stay up
Sounds like you may have a seal or valve problem in the lift. As to the precise problem, I dont know. Looks like a trip to the dealer. All makes and models have occassional problems but the 4000 series certainly has it's share. I hope the 4010 series is improved.
   / 4400 3 pt won't stay up #3
I have a similar problem with my 4100.
I have also noticed some foaming of the HD fluid when I removed removed my FEL. Could these two issues be related??
   / 4400 3 pt won't stay up #4
My 4400 did the same thing at about 120 hrs.
Dealer came and got it put in a new line and valve. Now at 140 hrs is starting to do the same thing.it is a .2000 model.
2011 Ford Econoline Cargo Van (A54814)
2011 Ford...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2025 Electric Diesel Fuel Pump with Hose Reel (A55852)
2025 Electric...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
