leonz
Super Member
Greetings and salutations John Deere board members,
I would like to pose a question to those of you who own the fourty four inch model two stage snow casters.
I have found that the lower mounting frame for the snow caster racks slightly to the right letting the snow caster sag to the right about 2 inches when the the snow caster is raised up and locked. The turnbuckle adjusters appear to be positioned at identical thread points/thread counts.
I thought at first it was the weight of the impeller drum but it seems to be centered properly. I did notice there is a lot of flexing in the 2 steel strap iron pieces that connects the snow caster to the tractor frame but the frame did not rack where the cross piece is mounted that holds the tensioner pulley and spring assembly.
I should probably see about purchasing a piece of channel iron and bolt it to the lower frame to stiffen it when the snow caster is removed for the summer season.
The tractor has been running fine, I use the space heater to warm it up when I need to use it in very cold weather as my garages are unheated.
I have the new chains on it and the suitcase weights have been a blessing for mowing and in the thin mud I have now. I just hope the ground freezes steady for the season. I wil hold off loading the tires with WWF this year and see how it goes, I was wondering if the larger four unit suitcase weight carrier will fit in the rear frame mounts of the LA115?
I changed the oil after twenty five hours and the air filter after 31 hours( I will be changing the air filter after 10 hour intervals from now on as the fumes are horrid even with good dust mask after 30 hours of use(probably due to the ethanol and 87 octane as well).
Thanks much
Thanks much
